trunk port identification from sh vlan command and unknown unicast frame
Jun 22nd, 2007
hi
i have a question about trunk port used in vlans , the command sh vlan brief used on switches does not display trunk ports is is true kindly help ?
secondly when a switch receives a frame with destination mac address not in its mac-address table will this frame be forwaded to all its ports except the incoming port keeping in mind that ports of this switch are in different vlans .
CSCO10892433 Sat, 06/23/2007 - 02:14
Hi, syed
The command "show vlan brief" will show you, for each vlan, the vlan name, vlan status and which ports are in this vlan. If you want to know which ports are the trunk ports, use "show interface trunk" command instead.
Unknown unicast frame in a specific vlan will be switched to:
1) all other access ports in the same vlan
2) all trunk ports in which this vlan is allowed and not pruned.
Please refer the following links:
sh vlan brief
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_6_ea2c/command/reference/cli_cmds.html#wp1025733
sh interface trunk
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_6_ea2c/command/reference/cli_cmds.html#wp1568414
SSLIN
syedsohailsarwar Sat, 06/23/2007 - 09:23
Dear SHIANG SHIUN LIN
thanks alot
actually i was going through the dumps of CCNA from testking site and there was a question petaining to sh vlan command ans in its explanation it is saying the ports u dont see in sh vlan are trunk ports , thanks for updating me on using sh interface trunk command but was the first method right or wrong
actually there is one question asked in CCNA simulation where in u have to log into a switch and tell which ports are trunk ports
and secondly on which ports of that switch will unknown unicast will be broadcasted
hope u ll clear my doubt
syedsohailsarwar Sat, 06/23/2007 - 09:37
also i have one more question
CSU/DSU are used for digital or analog
termination i guess it might be digital termination
and what about modems are they used for digital or analog termnination
