Cisco Catalyst 2960 Config Help ..Port Access
Jun 22nd, 2007
I'm looking for a way to do the following. One Ip Segment for devices on this switch 172.16.2.x /24
Port 1 can see all 48 ports
Port 2 Can see Port 1, 3,4,5
Port 3 Can see Port 1 only
Port 4 Can See Port 1, 2, and 6
Etc. Etc. This switch is our Router Switch with many vendors connect in using the 172.16.2.x /24 address and we need a way to block them from seeing certain devices connected to this switch.
vinayrajkp Fri, 06/22/2007 - 15:25
If you want to isolate at Layer 2 then you can consider private vlan. But the combination mentioned by you might be a bit difficult. But study private vlan and see how you can use it for your requirement.
mohammedmahmoud Fri, 06/22/2007 - 23:54
Since your switch is a layer 2 switch, thus the only way to achieve this is via Private VLAN, but unfortunately your switch doesn't support Private VLAN, and thus your only solution is to do inter-VLAN routing on a router, and then use ACL on the router to filter on layer 3 basis (plus using PVLAN edge (protected port)if you require 2 ports on the same VLAN not to communicate in the layer 2 - which is the only PVLAN option supported on your switch).
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
