Voice Port config for T1 controller
Jun 22nd, 2007
IOS (tm) 5300 Software (C5300-IS-M), Version 12.2(2)XB7, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Wed 14-Aug-02 16:55 by liha
Image text-base: 0x600089B0, data-base: 0x61120000
ROM: System Bootstrap, Version 11.2(9)XA, RELEASE SOFTWARE (fc2)
BOOTLDR: 5300 Software (C5300-BOOT-M), Version 12.3(18), RELEASE SOFTWARE (fc3)
AS5300VoIP_121 uptime is 1 day, 10 hours, 25 minutes
System returned to ROM by reload at 06:34:06 UTC Thu Jun 21 2007
System image file is "flash:c5300-is-mz.122-2.xb7.bin"
cisco AS5300 (R4K) processor (revision A.22) with 131072K/16384K bytes of memory.
Processor board ID 06469247
R4700 CPU at 150Mhz, Implementation 33, Rev 1.0, 512KB L2 Cache
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
Backplane revision 2
Manufacture Cookie Info:
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x30,
Board Hardware Version 1.0, Item Number 73-2414-03,
Board Revision A0, Serial Number 06469247,
PLD/ISP Version <unset>, Manufacture Date 10-Nov-1997.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
4 Channelized T1/PRI port(s)
48 Voice resource(s)
128K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
8192K bytes of processor board Boot flash (Read/Write)
Based on this show version command,I am configuring a T1 PRI, apparently it does not have a serial interface to setup for D channel. And the voice-port command is not available "unrecognized command error". I need some advise on what hardware are missing on my router. Thanks
Paolo Bevilacqua Fri, 06/22/2007 - 12:48
pls configure:
controller t1 x/y/z
pri-group
after that you will be abel to configure both interface x/y/z:D and voice-port.
Hope this helps, plese rate post if it does!
worldcalltel Fri, 06/22/2007 - 13:19
Another question. On show call history voice last, on the peer address field, is it always the dialed digits or it could be the ANI? based on my experience its always the called number, but somehow using an call center application the number that appears on peer address is the ANI so did not match in my pots dial-peer.
MNLA-C3660-2503-250.49#lastcall
GENERIC:
SetupTime=61555814 ms
Index=7874
PeerAddress=12345
PeerSubAddress=
PeerId=0
PeerIfIndex=0
LogicalIfIndex=0
DisconnectCause=10
DisconnectText=normal call clearing (16)
ConnectTime=0 ms
DisconnectTime=61571404 ms
CallDuration=00:00:00 sec
CallOrigin=2
ReleaseSource=2
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=0
ReceiveBytes=0
VOIP:
ConnectionId[0xC824E56B 0x2AA9021F 0x2DFC85DA 0xBE801A7]
IncomingConnectionId[0xC824E56B 0x2AA9021F 0x2DFC85DA 0xBE801A7]
RemoteIPAddress=64.192.251.11
RemoteUDPPort=55706
RemoteSignallingIPAddress=64.192.251.11
RemoteSignallingPort=58714
RemoteMediaIPAddress=64.192.251.11
RemoteMediaPort=55706
RoundTripDelay=0 ms
SelectedQoS=best-effort
tx_DtmfRelay=inband-voice
FastConnect=FALSE
AnnexE=FALSE
Separate H245 Connection=FALSE
H245 Tunneling=FALSE
SessionProtocol=cisco
ProtocolCallId=
SessionTarget=
OnTimeRvPlayout=0
GapFillWithSilence=0 ms
GapFillWithPrediction=0 ms
GapFillWithInterpolation=0 ms
GapFillWithRedundancy=0 ms
HiWaterPlayoutDelay=0 ms
LoWaterPlayoutDelay=0 ms
PlayoutMode = undefined
PlayoutInitialDelay=0 ms
ReceiveDelay=0 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
VAD = enabled
CoderTypeRate=g729r8 pre-ietf
CodecBytes=0
cvVoIPCallHistoryIcpif=-1
MediaSetting=flow-around
CallerName=telwise
CallerIDBlocked=False
OriginalCallingNumber=12345
OriginalCallingOctet=0x21
OriginalCalledNumber=25036326314224
OriginalCalledOctet=0xA1
OriginalRedirectCalledNumber=
OriginalRedirectCalledOctet=0xFF
TranslatedCallingNumber=12345
TranslatedCallingOctet=0x21
TranslatedCalledNumber=25036326314224
TranslatedCalledOctet=0xA1
TranslatedRedirectCalledNumber=
TranslatedRedirectCalledOctet=0xFF
GwReceivedCalledNumber=25036326314224
GwReceivedCalledOctet3=0xA1
GwReceivedCallingNumber=12345
GwReceivedCallingOctet3=0xA1
GwReceivedCallingOctet3a=0x0
Username=
Dial-Peer:
dial-peer voice 300 pots
description CCA
destination-pattern 2503632T
port 2/0/1
I'm getting confused here i have not experience this before. I hope you could help me with these also. Thanks.
Paolo Bevilacqua Fri, 06/22/2007 - 14:54
In show call history voice last, you have too look at CallOrigin, 1=answer, 2= originate.
For answer, will be called number, for originate will be calling.
Note that one call normally generates two entries!
Now, with DP 300 should work as long the called number begins with 2503632, on what conditions do you find that does not match ?
worldcalltel Sat, 06/23/2007 - 08:07
Apparently, the Peer ID field is set to 0 instead of the dial peer ID of 300. I assume that the call did not match on dial peer 300. All my dial peer is 100% working on my other VoIP Application. Im having a difficult time troubleshooting with Call Center Anywhere. May be you have an idea about CCA in regards to cisco gateways
Paolo Bevilacqua Sat, 06/23/2007 - 08:48
I generally do not care about "peer id". What you want to do, is "debug voice dialpeer" to see what is matching. What is your architecture? From where the call is coming in, and to where is supposed to go out?
worldcalltel Sat, 06/23/2007 - 10:38
Here is the screen shot from debug dialpeer
Inside dpMatchCore:
Jun 23 18:34:03.184: destination pattn: 25036326314224 expanded string: 25036326314224
Jun 23 18:34:03.184: Inside dpMatchCore:
Jun 23 18:34:03.184: destination pattn: 12345 expanded string: 12345
Jun 23 18:34:03.184: dpAssociateIncomingPeer_T null source route label
Jun 23 18:34:03.188: Inside dpMatchCore:
Jun 23 18:34:03.188: destination pattn: 25036326314224 expanded string: 25036326314224
Jun 23 18:34:03.188: destination pattn: 12345 expanded string: 12345
Jun 23 18:34:03.188: dpAssociateIncomingPeer_T null source route label
Jun 23 18:34:03.188: Inside dpMatchPeersMoreArg
Jun 23 18:34:03.188: dpMatchPeersMoreArg: Match Dest. pattern; called (25036326314224)
Jun 23 18:34:03.188: MatchNextPeer: Peer 300 matched partially
Jun 23 18:34:03.188: dpMatchPeersMoreArg: Result=1 after MATCH_ORIGINATE
Jun 23 18:34:36.577: Inside dpMatchCore:
Jun 23 18:34:36.577: destination pattn: expanded string:
Jun 23 18:34:36.577: destination pattn: Unknown expanded string: Unknown
Jun 23 18:34:36.577: dpAssociateIncomingPeer_T null source route label
Basically, the call flow would be CCA Telephony Server -> Voice Master -> Cisco Gateway.
Paolo Bevilacqua Sat, 06/23/2007 - 12:56
What matters to the GW are just the numbers. I assume the call comes in via VOIP and should go out via PRI. Now, if the called number has constant lenght, you would have a better match under DP 300 with:
destination-pattern 2503632........ <-- matches this prefix followed by 7 digits
and will dial the 7 digits via PRI. Is that ok ?
