3560 not routing Vlan1 when two routed interfaces configured
Answered Question
Jun 22nd, 2007
Can anyone tell me why Vlan1 10.90.152.0/24 does
not show up as directly connected in the routing table?
It's also is not advertising to other routers.
When I only configure one 192.168.0.x routed interface, then
the Vlan1 shows up.
I'm missing something here...
Thanks!
Current configuration : 2731 bytes
version 12.2
ip subnet-zero
ip routing
no ip domain-lookup
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Port-channel1
no switchport
ip address 192.168.0.5 255.255.255.252
interface GigabitEthernet0/1
no switchport
no ip address
channel-group 1 mode desirable
interface GigabitEthernet0/2
no switchport
no ip address
interface GigabitEthernet0/48
no switchport
ip address 192.168.0.2 255.255.255.252
interface Vlan1
ip address 10.90.152.1 255.255.255.0
router eigrp 1
network 10.0.0.0
network 192.168.0.0
no auto-summary
ip classless
ip default-network 172.23.0.0
ip http server
Gateway of last resort is not set
* 172.23.0.0/16 is variably subnetted, 2 subnets, 2 masks
D 172.23.31.0/26
[90/28416] via 192.168.0.1, 00:24:31, GigabitEthernet0/48
D 172.23.30.0/24
[90/28928] via 192.168.0.1, 00:24:31, GigabitEthernet0/48
192.168.0.0/30 is subnetted, 3 subnets
D 192.168.0.8 [90/1792] via 192.168.0.6, 00:24:29, Port-channel1
C 192.168.0.0 is directly connected, GigabitEthernet0/48
C 192.168.0.4 is directly connected, Port-channel1
192.168.1.0/30 is subnetted, 1 subnets
D 192.168.1.0 [90/28672] via 192.168.0.1, 00:24:31, GigabitEthernet0/48
Correct Answer by Edison Ortiz about 10 years 1 week ago
The interface needs to be up/up in order to install itself into the routing table. It can only be up/up if you have a port on VLAN 1 in connected state or if you create a trunk to another switch.
Overall Rating: 4 (2 ratings)
Correct Answer
Edison Ortiz Fri, 06/22/2007 - 11:10
  • Hall of Fame,
    Founding Member
ricschaaf Sat, 06/23/2007 - 06:12
Yes, there were no clients on any ports.
It shows up once I connect a client to a Vlan1 port.
I figured it was something basic.
Thank you
vinayrajkp Fri, 06/22/2007 - 15:16
Is vlan1 shut down. What happens when you give -
int vlan 1
no shut
Try changing the ip of gi0/48 to a different subnet than int port channel 1.
ricschaaf Sat, 06/23/2007 - 06:14
Will the no shut command do the same as if I connected a client to a port on Vlan1 ?
Edison Ortiz Sat, 06/23/2007 - 06:42
  • Hall of Fame,
    Founding Member
No, it won't.
ricschaaf Sun, 06/24/2007 - 03:05
Is there a way I can simulate having Vlan1
be up without actually having a client on a
port? I have (8) 3560's I'm testing but don't
have (8) clients I can connect to each...
Edison Ortiz Sun, 06/24/2007 - 06:13
  • Hall of Fame,
    Founding Member
Sure, you can configure trunking between the switches.
