How does 3750 allocate buffer
Jun 22nd, 2007
When doing the mls qos configuration, all information are related to percentage. For examle,
'mls qos srr-queue input buffers 50 50'
means both queues get 50% of the total buffer of that interface.
So how can you configure the actual buffers for one interface? Is that still the same using 'hold-queue 4096 out'?
richard.gu Fri, 06/29/2007 - 06:09
How do you know the queue is over-limit? Is there a setting that says 10 buffer is the limit?
