Layer 3 QoS on 6500
Jun 22nd, 2007
We have a small campus network, 3560/3570s used at the access level, 6500s w/ SUP720s at the core level. I've used a configuration as follows:
Access switches:
mls qos map cos-dscp 0 8 16 24 32 46 48 54
mls qos
interface range fa0/1-48
description End user port
autoqos voip cisco-phone
interface range gig0/1-4
description Uplink to Core 6500
mls qos trust cos
Core Switches:
mls qos
no mls flow ip
no mls flow ipv6
interface GigabitEthernet1/10
description Uplink to Access Switch
mls qos trust cos
interface PortChannel1
description Uplink to CoreB
mls qos trust cos
If I place a call between two phones on the same VLAN, I can verify the both DSCP and CoS values are being passed accordingly by using the "show mls qos interface <int> statistics" command. This works even when the phones are on two different access switches. So QoS at the Layer 2 happening just fine.
However, when I look at a call between two VLANs, I don't see the CoS or DSCP values making it from destination port. I'm concluding the Core 6500 is resetting these values to 0 when it does the Layer 3 translation.
To debug, I tried a simple MQC config:
class-map match-any VoIP
match ip dscp ef
match ip precedence 5
policy-map QoS-Test
class VoIP
trust dscp
interface Vlan110
description Layer 3 Interface for Phones in Building 1
service-policy input QoS-Test
#show policy-map interface Vlan110
Service-policy input: QoS-Test
class-map: VoIP (match-any)
Match: ip dscp ef
Match: ip precedence 5
trust dscp
Earl in slot 5 :
0 bytes
5 minute offered rate 0 bps
aggregate-forwarded 0 bytes
Class-map: class-default (match-any)
40 packets, 3860 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: any
So it looks almost like the DSCP values are never hitting the 6500. Couple questions:
1) Should I be trusting just DSCP rather that CoS in this case?
2) Could "no mls flow" be interfering with QoS?
3) Are the empty stats in "show policy-map interface" simply because the interface isn't heavily loaded?
chrihussey Mon, 06/25/2007 - 10:04
Are you running HSRP across the core switches for the VLANs?
How does the routing between the VLANs take place?
Is the port channel between the core switches configured as a trunk, if so what is the native VLAN and are you routing across this VLAN?
johnnylingo Tue, 06/26/2007 - 11:33
We do run HSRP, and routing between the VLANs takes place on the Core switches via SVIs. OSPF is the IGRP used. The port channel interfaces are 802.1Q trunks.
In any case, I found out my problems. On the trunk interfaces, I should have used "mls qos trust dscp" instead of "mls qos trust cos" to make sure QoS was working at the layer 3 level. I corrected this, and also found out one of the server distribution switches was missing "mls qos" from its global config. Once corrected, End to End QoS works perfectly.
I still get empty stats when doing the test Policy-Map on the SVI interface, but get plenty of numbers when applied to the physical interface. I vaguely remember reading that this is normal, but am not 100% sure on this.
