royalblues Sat, 06/23/2007 - 01:11
  • Green, 3000 points or more
If you are talking about comparing a router configurations after the change, then tools like Cisco works, solarwinds cirrus manager,opsware can do that.
They archive the old configuration when a configuration chnage is made and then you can compare the differences for the entire running configuration and not only routes
HTH, rate if it does
Narayan
khaderbasha Sat, 06/23/2007 - 04:58
Hi Narayan,
Thanks for the reply. I want to compare routing table before and after migration, I want them to be same. I want to see all networks before and after migration. Any suitable tool for this funtion ?
Thanks.
khaderbasha Sat, 06/23/2007 - 09:02
Tried windiff, it compares two files sequentially:
For ex:
file1:
10.1.10.0/24
10.2.10.0/24
10.3.10.0/24
file2:
10.2.10.0/24
10.3.10.0/24
10.1.10.0/24
are two different files for windiff, but wrt routing both routing tables have same routing entries. I am looking for a tool which checks logically if same routes are present. Any additional help is appreciated.
