Cisco IAD 2430 error.Please help me!!!
kyipcom84
I have some problems about the IP COM system.
1.when a call had finished, a few minutes later I made another call, but i could not hear any dial tone. After that, showing command in IAD 2430 (connect directly to telephone via FXS port), I found that the port of this telephone number was connected. But infact, the call had finished as below :
----------------------------FLEX VOICE CARD 0 ------------------------------
*DSP VOICE CHANNELS*
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABRT PACK COUNT
C5510 001 01 None 4.4.6 busy idle 0 0 2/1 01 0 1200371/17
C5510 001 02 g711alaw 4.4.6 busy idle 0 0 2/0 00 0 1160/921
C5510 001 03 g711alaw 4.4.6 busy idle 0 0 2/5 05 0 989/452 <======= this number on port had finished and I could not hear dial tone
C5510 001 04 g711alaw 4.4.6 busy idle 0 0 2/23 23 0 401/929
C5510 001 05 None 4.4.6 idle idle 0 0 0 0/0
C5510 001 06 None 4.4.6 idle idle 0 0 0 0/0
C5510 001 07 None 4.4.6 idle idle 0 0 0 0/0
C5510 001 08 None 4.4.6 idle idle 0 0 0 0/0
C5510 001 09 None 4.4.6 idle idle 0 0 0 0/0
C5510 001 10 None 4.4.6 idle idle 0 0 0 0/0
C5510 001 11 None 4.4.6 idle idle 0 0 0 0/0
C5510 001 12 None 4.4.6 idle idle 0 0 0 0/0
Please take a look in the bold row. When i used command "shutdown" then used "no shutdown" on this port, this port became normally and I can hear dial tone.
2. After a call finished, I hang up telephone. 2 to 4 seconds later, it will be ringing until I pick up although there is no incoming call.
3. During the calling conversation, the call is usually automatically dropt (we can't hear any sound from each other)
paolo bevilacqua
This has been replied already in another thred you opened.
