Cisco fax server solution
Jun 23rd, 2007
we have a customer interested in a cisco fax server 9.3 solution.
I would like to know if anyone has experience and knows which is the best solution between the following:
1) IP T.38 Fax Relay with H.323 between gateway and callmanager and SIP between gateway and Cisco fax server
2) ISDN/MGCP Fax relay mode with E1 between gateway and and Cisco fax server and MGCP between gateway and callmanager
Solution 1 is for sure the cheapest one so why should someone choose solution 2?
Does anyone know if the Windows 2003 server software and license is provided with the cisco CFS-9-X-BUS-SERV cd? Or the customer has to provide to the operating system?
in the following site: http://www.cisco.com/en/US/products/ps6178/products_data_sheet0900aecd802638f9.html
I read that "The Cisco MCS 7825-I and MCS 7825-H support only boardless fax over IP (FoIP)."
Does this means that in 7825 series is not possible to use TR1034 PCI cards?
Thank you very much in advance
liettig Fri, 07/06/2007 - 01:40
thanks for your answer but the link you provided is the same I wrote in my post.
I am also struggling with a Cisco FaxServer solution. I am dealing with a deployment that may grow into a Cisco IPT pilot with CallManager so I want to be able to build into that. The customer is anticipating the need for 30 channels and will look to purchase a PRI from telco to interface to the PSTN. I am picturing that I would purchase an IOS gateway to run H323. This would provide PRI connectivity to the PSTN; however, I am confused about the signaling to the FaxServer (using the Brooktrout card) from the gateway. Is the signaling just T-1 CAS to the IOS gateway?
The doc is pretty un-clear to me.
Thanks.
Mike.
1 ) IP T.38 Fax Relay with H.323 between gateway and callmanager and SIP between gateway and Cisco fax server
GW---H.323---CUCM----SIP---CFS
NO problem at all and advantage of use CUCM and perhaps CDR.
E1---GW---MGCP---CUCM---CFS
Not sure why you want to do this but you need to be carefull because the protocol (Mgcp or H.323) determine if you need an extra E1 since partial Fax or voice routing is not possible on certain protocols such as MGCP.
No the CFS software only comes with the CFS software no OS system is on the cd's.
Let me know if you need more information.
Marco
