ISP line on HWIC-1FE
Answered Question
Jun 23rd, 2007
can we terminate ISP line on HWIC-1FE card.
And if we use 4 ISP line on one router each line is 2mbps.for thise solution, which router is best.
Correct Answer by paolo bevilacqua about 9 years 10 months ago
Sure you can. To terminate multiple circuits you can also use the etherswitch module like hwic-4esw. The limitation is that these don't support more than one PPPoE per card.
Any modern router will do, starting from 18xx and up. Choice is often made by budget.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Sat, 06/23/2007 - 05:43
  • Hall of Fame,
    Founding Member
