Paolo Bevilacqua Sat, 06/23/2007 - 07:01
It gets an address via DHCP or static config, then contacts the call manager via TFTP. It downloads a config file then registers.
hope this helps, please rate post if it does!
mmirghani Sat, 06/23/2007 - 07:15
Do I need any IOS voice & DSP for Phone to connected to main site
Paolo Bevilacqua Sat, 06/23/2007 - 07:19
You don't need any voice feature except on the router that is connected to the phone network, sometime called voice gateway.
What you may need, if the remote phones are connected via slow links, is QoS configuration on the routers that are connecting the slow links.
Thanks for the nice rating and good luck!
mmirghani Sat, 06/23/2007 - 07:42
Thanks for helpfull reply
My last question is i need IOS voice & DSP for my router , I only connected to main site via WAN only no PSTN needed in this setup
Paolo Bevilacqua Sat, 06/23/2007 - 08:44
As I said above, generally you do not need voice features and DSP except on a router that is connected the the telephone network, if any.
