< 6148a problom > Pls help me~
leojchina
I'm Chinese, there is a problem with my work,thank you all first!
the enviroment:
UNKNOWN line card: ws-x6148a-ge-tx
Cisco Catalyst 6506 with super engin 2
Old IOS 12.1 (Running IOS)
new IOS s222-ipservicesk9_wan-12.2-18.sxf6.bin (prepare to Upgrade)
PCMCIA Flash card 64M (new ios is 50M, placed here)
sup-bootflash:64M running ios is placed here
config-register 0x2102
bootvar:
boot system disk0:
boot system disk0:s222-ipservices.....
boot system flash disk0:s222...
boot system flash sup-bootflash:c6k...(Running IOS)
rommon 1> dev
..... pcmcia ... slot0(disk0: was shown in ios, slot0 here in Rommon??)
with the configuration was shown,the switch was able to start with disk0,just as the PCMCIA card was not in ! it start with sup-bootflash everytime!
help me , i was so worry about that i did't eat anything all the day..
My English is not very good,if the situation i had shown is not very clearly, pls tell me ,
my msn is love.leo@msn.com
7 Replies 7
paolo bevilacqua
Not very clear.
Please include the entire output and console log when trying to boot with the new IOS. If you do commands like "show boot" or "show device" please do not cut the output because ti makes impossible to understand what is going on.
Old6506_RP#sh start
Using 12311 out of 391160 bytes
version 12.1
service timestamps debug uptime
service timestamps log uptime
service counters max age 10
hostname Old6506_RP
boot system disk0:
boot system disk0:s222-ipservicesk9_wan-mz.122-18.SXF6.bin
boot system flash disk0:s222-ipservicesk9_wan-mz.122-18.SXF6.
boot system flash sup-bootflash:c6sup22-psv-mz.121-25.E4.bin
clock timezone GMT 8
firewall module 5 vlan-group 1
firewall vlan-group 1 30,34,36,40,66
vtp domain hnyd
vtp mode transparent
ip subnet-zero
Old6506_RP#
Old6506_RP#reload
Proceed with reload? [confirm]
00:22:27: %SYS-5-RELOAD: Reload requested
00:22:27: %OSPF-5-ADJCHG: Process 200, Nbr 10.154.35.174 on Vlan34 from FULL to DOWN, Neighbor Down: Interface down or detached
00:22:27: %OSPF-5-ADJCHG: Process 200, Nbr 10.154.35.126 on Vlan34 from FULL to DOWN, Neighbor Down: Interface down or detached
00:22:27: %OSPF-5-ADJCHG: Process 200, Nbr 10.154.35.125 on Vlan42 from FULL to DOWN, Neighbor Down: Interface down or detached
00:22:27: %OSPF-5-ADJCHG: Process 200, Nbr 10.154.35.117 on Vlan43 from FULL to DOWN, Neighbor Down: Interface down or detached
00:22:27: %STANDBY-6-STATECHANGE: Vlan16 Group 16 state Active -> Init
00:22:27: %STANDBY-6-STATECHANGE: Vlan67 Group 67 state Active -> Init
00:22:27: %STANDBY-6-STATECHANGE: Vlan68 Group 68 state Active -> Init
00:22:27: %STANDBY-6-STATECHANGE: Vlan69 Group 69 state Active -> Init
00:22:30: %OIR-SP-6-CONSOLE: Changing console ownership to switch processor
00:22:30: SP: The PC in slot 5 is shutting down. Please wait ...
00:22:30: SP: PC shutdown completed for module 5
00:22:30: %C6KPWR-SP-4-DISABLED: power to module in slot 5 set off (Reset)
Reload scheduled in 36 seconds
Old6506_RP-sp>
Old6506_RP-sp>en
Old6506_RP-sp#reload
00:22:43: %SYS-SP-5-RELOAD: Reload requested
00:22:43: %OIR-SP-6-CONSOLE: Changing console ownership to switch processor
System Bootstrap, Version 6.1(3)
Copyright (c) 1994-2000 by cisco Systems, Inc.
c6k_sup2 processor with 524288 Kbytes of main memory
Autoboot executing command: "boot bootflash:c6sup22-psv-mz.121-25.E4.bin"
Self decompressing the image : ##############################################################################################
when the boot configuration is entered,the switch reload,an restart with old ios image in bootflash
After the image in bootflash starts, it should load the one in disk0: If does don't that, try formatting the bootflash completely, and remove the stamente from config. At this point it should load from disk0:
Before you do that, make sure the image in disk0: is valid and readable.
i had try to delete the last line of the bootvar, which is < boot system flash sup-bootflash:... > . but i still loaded ios from the sup-bootflash:
if the file can be upload to disk0:, does it mean that the disk0 is OK ?
i think maybe something goes wrong with my ATA PCMCIA card...
There is ".bin" missing in boot var:
"boot system flash disk0:s222-ipservicesk9_wan-mz.122-18.SXF6."
should be
"boot system flash disk0:s222-ipservicesk9_wan-mz.122-18.SXF6.bin"
Also, don't forget to do "copy run start", since bootvar is written in nv memory.
Good catch.
And the statement withe correct filename but without the "flash" keyword doesn't work as it a attempts to load via TFTP.
The configuration in the switch is "boot system flash ......bin", i forgot to write in the shown above ,thank you all the same
i will try again to upgrade the ios this week, and i'll take the result here
