BGP, non-exist, advertise config assistance
Jun 23rd, 2007
I have a lab setup and I am trying to configure advertise and non-exist maps.
I have two routers "BGP" and "Edge" that are communicating via BGP. I am distributing the default route from the "BGP" router into the "Edge" router and that part is working.
I want to advertise:
2.1.1.64 0.0.0.31
out the "Edge" router if:
6.6.1.184 0.0.0.31
is not in the "Edge" route table.
But it is not working.
I would like to see the 2.1.1.64 subnet in the "BGP" router route table.
The "non-exist" subnet is not available to either router, so shouldnt I be advertising the "advertise" subnet?
Is there something other that what I have in the "Edge" router shown below needed to accomplish this?
router bgp 70
no synchronization
bgp log-neighbor-changes
network 6.6.1.184 mask 255.255.255.252
network 6.2.1.128 mask 255.255.255.224
network 2.1.1.64 mask 255.255.255.224
neighbor 6.6.1.189 remote-as 701
neighbor 6.6.1.189 version 4
neighbor 6.6.1.189 soft-reconfiguration inbound
neighbor 6.6.1.189 prefix-list 1 out
neighbor 6.6.1.189 advertise-map ADVERTISE non-exist-map NON-EXIST
no auto-summary
ip prefix-list 1 seq 5 permit 6.2.1.128/27
ip prefix-list 1 seq 6 permit 2.1.1.64/27
ip prefix-list 1 seq 10 deny 0.0.0.0/0 le 32
access-list 5 permit 0.0.0.0
access-list 60 permit 2.1.1.64 0.0.0.31
access-list 61 permit 6.6.1.184 0.0.0.31
route-map NON-EXIST permit 10
match ip address 61
route-map BGPtoOSPF permit 10
match ip address 5
route-map ADVERTISE permit 10
match ip address 60
Overall Rating: 5 (5 ratings)
sundar.palaniappan Sat, 06/23/2007 - 13:02
Can you double check access list 61. Should that be.
access-list 61 permit 6.6.1.182 0.0.0.3
The WC mask of .31 doesn't appear to be correct. It looks like you are trying to track another BGP link in the non-exist map and disappearance of that route is to trigger this advertisement.
If you are still having issues then post the output of 'show ip route'.
Sundar
wilson_1234_2 Sat, 06/23/2007 - 15:17
Thanks for the reply Sundar.
I noticed the WC mask and thought it was incorrect, I changed it to 31.
can you explain why it is 3?
also, after putting it back to 3, I still do not see the desired subnet in the routing table:
Edge#sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, * - candidate default
U - per-user static route, o - ODR
Gateway of last resort is 63.65.190.189 to network 0.0.0.0
4.0.0.0/32 is subnetted, 1 subnets
S 4.2.2.2 [1/0] via 63.65.190.189
65.0.0.0/27 is subnetted, 1 subnets
C 65.207.187.128 is directly connected, Ethernet0
10.0.0.0/24 is subnetted, 1 subnets
O 10.100.73.0 [110/20] via 65.207.187.130, 00:01:19, Ethernet0
63.0.0.0/30 is subnetted, 1 subnets
C 63.65.190.188 is directly connected, Serial0
B* 0.0.0.0/0 [20/0] via 63.65.190.189, 00:02:20
BGP>en
Password:
BGP#sh ip route
Gateway of last resort is 20.30.40.1 to network 0.0.0.0
B 65.207.187.128 [20/0] via 63.65.190.190, 00:01:47
20.0.0.0/30 is subnetted, 1 subnets
C 20.30.40.0 is directly connected, Ethernet0
S* 0.0.0.0/0 [1/0] via 20.30.40.1
JORGE RODRIGUEZ Sat, 06/23/2007 - 18:09
As Sundar indicated, it needs to be 0.0.0.3 and not 0.0.0.31 based on you network
statement under bgp and mask "network 6.6.1.184 mask 255.255.255.252
,this is very important when using ACLs to get the right inversed mask.
go to this link which will explain in much more details.
http://www.mdh.se/netcenter/ct3790/ct3790_HT2005_p2/ACLs.pdf
Also, when making changes to bgp you need to do a bgp soft reset for the new changes to take effect.
http://www.cisco.com/en/US/products/ps6599/products_data_sheet09186a0080087b3a.html
Rgds
Jorge
sundar.palaniappan Sat, 06/23/2007 - 20:23
Wilson,
The reason why network 2.1.1.64/27 isn't being advertised by BGP is because the Edge router does not have a route to that network in the routing table. The network statement under BGP process alone doesn't cause the router to advertise the network but it also requires a route to that network exist in the routing table.
Try adding 'ip route 2.1.1.64 255.255.224.0 (null0)' and test. You can substitute the null interface with another interface or next hop. As Jorge indicated you may have to do 'clear ip bgp soft * out' for any configuration change to take effect.
Sundar
wilson_1234_2 Sun, 06/24/2007 - 06:22
Thanks Sundar and Jorge,
Ok, so I understand this:
If I had two locations DR (where both the edge and BGP routers are located),
And I want to advertise the 2.1.1.64 subnet from DR when it is no longer available (site is wiped out and DR is not getting updates via MPLS connection from HQ)
Wouldnt it be removed out of the Edge router route table at that point?
Also, what are these lines doing:
ip prefix-list 1 seq 5 permit 65.207.187.128/27
ip prefix-list 1 seq 6 permit 206.113.198.64/27
Pavel Bykov Sun, 06/24/2007 - 09:11
In your configuration, prefix-list lines allow only two networks (65.207.187.128/27 and 206.113.198.64/27) to be advertised to the neighbor 6.6.1.189.
wilson_1234_2 Sun, 06/24/2007 - 09:34
thanks, so that leaves the last question:
If BGP will not advertise the subnet unless it is in the route table of that router, and the only way it is in the route table is from the HQ site that has been wiped out,
Does that mean that if you want to advertise the subnet in the Disaster Recovery scenario, that you have to put a static route in the Edge router to make sure the router is advertised with the advertise and non exist maps?
sundar.palaniappan Sun, 06/24/2007 - 11:41
That's correct!!
If you want the Edge Router to not use the static route if it's learning the network that you want to advertise from the HQ router then you can configure a floating static route aka route with a higher admin distance. This would cause the Edge router to use the static route only when the route learned from the HQ via the routing protocol disappears.
ip route 2.1.1.64 255255.255.224 200 --> 200 is the Admin distance.
Sundar
