ip cache flow output question
Jun 23rd, 2007
In some of the ping lines from "ip cache flow" shows "print" for scrp. I typically expect 0, 3, or 7 here, but have never seen "print" until now. What does this mean?
Thanks.
Overall Rating: 1 (1 ratings)
vmoopeung Thu, 06/28/2007 - 10:00
The command shows how to associate the headings with the correct data fields when there are two or more lines of headings and two or more lines of data fields. The first line of the headings is associated with the first line of data fields. The second line of the headings is associated with the second line of data fields, and so on.
When other features such as IP Multicast are configured, the number of lines in the headings and data fields increases. The method for associating the headings with the correct data fields remains the same
http://www.cisco.com/en/US/products/sw/iosswrel/ps5187/products_command_reference_chapter09186a008017cf45.html#wp1066187
