Internationational Templates for Call Mgr 5.1
Answered Question
Jun 23rd, 2007
We will be setting up a Call Mgr 5.1 system in Ireland in the coming weeks, and I was told that there are international templates that cisco has created to make setup easier (dial tones/rings, announcers, etc).
If so were might I find these templates and are they easy to install/configure?
-Scott
Correct Answer by Rob Huffman about 9 years 8 months ago
Hi Scott,
The files you are referring to are Locale Files. Have a look;
The Cisco Unified Communications Locale Installer is used in connection with Cisco Unified Communications Manager and other Cisco Unified family of products. The installer adds support for languages other than English, in addition to network tones and cadences not specific to the United States.
http://www.cisco.com/application/pdf/en/us/guest/products/ps7036/c2001/ccmigration_09186a0080792e61.pdf
You can download the Locale Files here;
http://www.cisco.com/cgi-bin/tablebuild.pl/callmgr-locale-51
Hope this helps!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
Rob Huffman Sun, 06/24/2007 - 08:56
Hi Scott,
Hope this helps!
Rob
Rob Huffman Sun, 06/24/2007 - 09:13
Hi Scott,
You are most welcome! Best of luck in Ireland, sounds like a great gig :)
Take care,
Rob
