CS-MARS with ASA failover pair and IPS
Jun 24th, 2007
Hi.
Has anyone implemented CS-MARS with ASA in active/standby, each with IPS modules?
What is the procedure for adding the devices to CS-MARS - do I define each box separately -(remember the active and standby both have the same name) or do I just define one ASA using the failover address?
Any reccommendations would be welcome,
regards
Mick.
Overall Rating: 5 (2 ratings)
joemarr_brodart Sun, 06/24/2007 - 10:45
I?ve asked this question before but never really received a response. So what I'm about to say is based only on my experience.
I added only the active firewall, and then added each IPS blade as a module to the active firewall.
The only drawback is that MARS does not seem to acknowledge failover capabilities. I say this because only one IPS blade (obviously)generates alerts, so the second blade will cause MARS generate an Inactive CS-MARS reporting device event.
m.reay Sun, 06/24/2007 - 23:44
Thanks for the reply.
That is exactly the way I set it up - Active ASA with both modules defined in the active device.
About the second module not generating alarms - I wouldn't expect it to whilst it was in standby mode as it wouldn't be passing traffic.
When the ASA fails over - the second module should then start to generate alerts.
m.reay Mon, 06/25/2007 - 12:03
Hi Andrew - thanks for replying.
I actually added the ASA using the active addresses and added both of the IPS devices as modules of the ASA rather than as separate devices.
This seems to work fine - can you see any problem doing it this way?
Thanks and regards
Mick.
andrew.burns Mon, 06/25/2007 - 23:33
  • Gold, 750 points or more
Hi Mick,
That should work fine - as far as I can tell MARS doesn't care whether the IPS modules are internal or external. I tried it both ways and couldn't see any difference in functionality.
Andrew.
