inter pvlan communication
Jun 24th, 2007
  • Bronze, 100 points or more
Hi guys,
hope u r doing fine.
I have a problem with private vlans.In a shared environment, I am supposed to host multiple webservers under a private vlan
like
PRIMARY VLAN 1
_______________________
secondary VLANs
1 2 3
Servers from secondary vlan 1 can never see a server in Sec.vlan 2 or 3 and vice versa.I need this to be accomblished in layer two.
I hope,If im going to layer three and subnetting then there is no need of private vlans.
Is there any possiblity?
thanks in adance
Rajeev.S
Overall Rating: 4 (1 ratings)
paolo bevilacqua Sun, 06/24/2007 - 06:05
  • Hall of Fame,
    Founding Member
with vlan, private or not, there is no communciations at layer 2 between vlans.
Once you place a router, or layer 3 switch, there may be communication at layer 3 that you can limit with use of configuration.
In any case, each vlan should use a different IP subnet.
