Aironet 1200 and VLAN's
Jun 24th, 2007
I'm struggle configuring an Aironet 1200 with 2 VLAN's.
I want to setup the AP with one VLAN for normal LAN access and a second VLAN as guest VLAN for internet access only. The AP is connected to a 2524 HP layer 2 switch which is connected further to a 9208 layer 3 HP switch.
AP config is attached as config.txt
The LAN wireless access is working fine, but I can't access the guest VLAN from my wireless clients. I reserved 192.168.14.0/24 for the wireless guest VLAN and 172.16.11.0/24 for the internal LAN. I can ping 192.168.14.2, my internet GW, from the AP. The wireless clients can ping each other, but not the internet GW. When I put a wired client into the same VLAN, all is working perfect.
What do I miss ?
Claudia
farkascsgy Mon, 06/25/2007 - 01:30
  • Silver, 250 points or more
The problem is that you don't bridge the radio interface with Fasthethernet.
interface Dot11Radio0.30
encapsulation dot1Q 30
bridge-group 30 <--- this line is missing
no ip route-cache
no cdp enable
interface FastEthernet0.30
no ip route-cache
no cdp enable
Also the uplink of the AP should be trunk with native vlan 1.
bye
FCS
Please rate me if I helped.
claudia1910 Mon, 06/25/2007 - 01:51
thanks for your reply.
I put in both lines, but still no success.
I'm nearly sure the uplink switches are configured correctly, as a wired client connected to the same uplink switch (the 2524) can access the internet GW. In HP language, the port the AP is connected to is untagged member of VLAN 1 and tagged member of VLAN 30.
Claudia
farkascsgy Mon, 06/25/2007 - 02:13
That's works for me:
interface Dot11Radio0.590
encapsulation dot1Q 590
no ip route-cache
bridge-group 90
bridge-group 90 subscriber-loop-control
bridge-group 90 block-unknown-source
no bridge-group 90 source-learning
no bridge-group 90 unicast-flooding
bridge-group 90 spanning-disabled
interface Dot11Radio0.606
encapsulation dot1Q 606
no ip route-cache
bridge-group 6
bridge-group 6 subscriber-loop-control
bridge-group 6 block-unknown-source
no bridge-group 6 source-learning
no bridge-group 6 unicast-flooding
bridge-group 6 spanning-disabled
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
no bridge-group 1 source-learning
bridge-group 1 spanning-disabled
hold-queue 160 in
interface FastEthernet0.590
no ip route-cache
bridge-group 90
interface FastEthernet0.606
no ip route-cache
bridge-group 6
interface BVI1
ip address 10.xx.xx.xx 255.255.255.0
Try to use only tagged frames for Radio Interface, native vlan is only for BVI1.
The connected switch port is trunk with native vlan: BVI vlan and in my case 590 and 606 is trunked over the link with tags.
bye
FCS
claudia1910 Wed, 06/27/2007 - 06:08
whatever I did changed nothing, so I decided to reset the AP and startover from scratch. This did the job. I ended up with the following configuration:
dot11 vlan-name Guest-VLAN vlan 30
dot11 vlan-name default vlan 1
dot11 ssid HH-FIR-01
vlan 1
authentication open eap eap_methods
authentication network-eap eap_methods
authentication key-management wpa
infrastructure-ssid optional
dot11 ssid IT-Guest
vlan 30
authentication open
guest-mode
wpa-psk ascii xxx
bridge irb
no ip address
no ip route-cache
ssid HH-FIR-01
ssid IT-Guest
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0
channel 2412
station-role root
world-mode dot11d country DE both
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 unicast-flooding
no ip route-cache
bridge-group 30
bridge-group 30 subscriber-loop-control
bridge-group 30 block-unknown-source
no bridge-group 30 source-learning
no bridge-group 30 unicast-flooding
bridge-group 30 spanning-disabled
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
no ip route-cache
bridge-group 1
no ip route-cache
bridge-group 30
interface BVI1
ip address 172.16.11.15 255.255.255.0
no ip route-cache
ip default-gateway 172.16.11.1
Thanks for your help
Claudia
