CCNA 640-801
Answered Question
Jun 24th, 2007
Hi Cisco Engineers,
I want to take CCNA 640-801 exam but Should I recertify to the new CCNA certification if it's applied....
Ibrahim Alwahidi
Correct Answer by mohammedmahmoud about 9 years 8 months ago
Hi Ibrahim,
640-801 is not available after November 6, 2007, if you have taken it then you won't need to recertify, but if you haven't taken it you should go to the new exam:
http://www.cisco.com/web/learning/le3/le11/learning_all_certification_exams_list.html
http://www.cisco.com/web/learning/le3/current_exams/640-802.html
http://www.cisco.com/web/learning/le3/current_exams/640-801.html
P.S: Please Ibrahim, post any Certifications question in the Certifications forum and not in the WAN routing and switching, just for the forum to be more comprehensive and best utilized.
HTH,
Mohammed Mahmoud.
Overall Rating: 5 (1 ratings)
Correct Answer
mohammedmahmoud Sun, 06/24/2007 - 22:58
Hi Ibrahim,
HTH,
Mohammed Mahmoud.
alwahidi22 Mon, 06/25/2007 - 05:39
Thanx Mohammad for your immediate replies
Ibrahim Alwahidi
