CUE and Message notification for group
Jun 24th, 2007
Hi all,
We have Cisco Unity Express 2.3, and I have set up two General Delivery Mailboxes. They are set up the same (different extensions of course) but I can only set up one for the message notification.
The other I can tick the box to enable notification but when I go to the Notification tab there is the message "No Notification Devices found for User/Group".
Can someone enlighten me as to what could be wrong?
thanks, justin
rob.huffman Mon, 06/25/2007 - 08:58
Hi Justin,
Is it possible to use the CLI instead of the GUI?
Enabling Message Notification for a Subscriber or Group
Before configuring message notification on a device for a subscriber or group, enable the message notification capability for the subscriber or group.
Starting in Cisco Unity Express configuration mode, use the following command to enable message notification:
voicemail notification owner owner-id enable
where owner-id is the username of the subscriber or groupname of the group that requires the message notification capability.
The following example enables message notification for the subscriber user5 and the group sales:
se-10-0-0-0# config t
se-10-0-0-0(config)# voicemail notification owner user5 enable
se-10-0-0-0(config)# voicemail notification owner sales enable
se-10-0-0-0(config)# end
Now configure message notification on one or more devices for the subscriber or group.
Hope this helps!
