load sharing after 50% utilization of primary link
Jun 24th, 2007
ihave 2811 with 2 lease lines connected to service provider. i want to utilze both link but 2nd link will be utilzed once primary link would be utilized more then 50%. any solution available other then multi linking
Zahid Fayaz
ack_cisco Sun, 06/24/2007 - 21:38
Hai,
I am also expecting solution for same senario..
A.ChenthilKumar
Pavel Bykov Mon, 06/25/2007 - 00:14
  • Silver, 250 points or more
What routing protocol are you using?
You can probably achieve this by manipulating routing protocol.
paolo bevilacqua Mon, 06/25/2007 - 00:47
  • Hall of Fame,
    Founding Member
In short, is not possible.
Cisco has intreoduce sometingh called OER, but is new and may not be right for any situation.
You can also try some config with IP SLA and tracking, but once again it does not seem to be a best practice.
ack_cisco Tue, 06/26/2007 - 06:11
hai,
Ok fine and Thanks
If you find any option in nearby timing you can inform me..
A.ChenthilKumar
