SNMPv3 OIDs for LMS 2.6/RME
Jun 24th, 2007
we would like to implement SNMPv3 on our 2950er Switches, but only with the absolute minimum OIDs in the write SNMP-View. What OIDs are used by LMS2.6 and the RME ?
Overall Rating: 5 (1 ratings)
Joe Clarke Mon, 06/25/2007 - 05:28
This is a bit of a moving target depending on what you want to use in LMS. Obviously, the CISCO-CONFIG-COPY-MIB objects along with tsMsgSend should be allowed. If using CiscoView this list can be quite extensive, and subject to change with new package versions.
However, I would caution you against using SNMPv3 with the 2950 series. If you do, User Tracking and the STP features of Campus Manager will no longer work. There is a known limitation in the code that runs on these switches that they do not support SNMP contexts, and thus there is no way to get per-VLAN MAC addresses from these switches.
