ASA 7.2 remote access VPN
Jun 24th, 2007
Hi All,
I created a remote access VPN on my ASA through ASDM. The internal LAN in 192.168.14.x; the remote access pool uses 10.254.14.x; my vpn client logs in normally, but once in, i am not able to reach 192.168.14.x; any tips?
zroth Mon, 06/25/2007 - 02:52
it can be you have not configured access-list nonat,ex. access-list nonat perm ip 10.254.14.0 255.255.255.0 10.254.14.0 255.255.255.0
and command nat (inside) 0 access-list nonat
HtH
Zdenek
zroth Mon, 06/25/2007 - 02:55
Sorry fot the mistake,
access-list shall be access-list nonat perm ip 192.168.14.0 255.255.255.0 10.254.14.0 255.255.255.0
Fernando_Meza Mon, 06/25/2007 - 03:29
  • Gold, 750 points or more
Hi .. please check:
1.- That your routing is correct. The segment 192.168.14.x should know how to get back to 10.254.14.X. those returned packets need to reach the inside interface of the ASA.
2.- You might need to enable NAT-T whiach is not enabled by default. The command is
crypto isakmp nat-traversal 20
I hope it helps .. please rate it if it does !!!
m-mneimneh Mon, 06/25/2007 - 03:35
Hi guys,
it turned out i needed to add the following to the inside access-list:
access-list inside_acl extended permit ip any 10.254.14.0 255.255.255.0
when applied, i could get responses from 192.168.14.x machines.
thank you for your contributions.
