Jon Marshall Mon, 06/25/2007 - 04:40
Could you clarify what you mean. Do you mean
1) give access to multiple vlans down a VPN tunnel. If so this is relatively easy as you just define the vlan subnets in the crypto access-list on the ASA.
2) Extending a vlan down a VPN tunnel ?
Jon
Kjetil Fleten Mon, 06/25/2007 - 21:32
I want to extend multiple VLANs down the tunnel, so that all my VLANs one the primary site can comunicate with the same VLANs on the secondary site.
I have tried to make 802.1q tunneling with GRE, but that seems impossible with the ASA ? Right now I am trying multiple l2l-VPN's between the devices, one pr. VLAN. (Using a lot of ethernet ports though, since I can not use trunking on the inside ?)
Kjetil
