LMS 2.6 Upgrade
Jun 25th, 2007
I would like to change the default installation directory for the LMS 2.6 upgrade becuase the previous version LMS 2.5.1 was installed in a diffrent folder. Possible?
Overall Rating: 5 (1 ratings)
vkapoor5 Fri, 06/29/2007 - 05:46
  • Bronze, 100 points or more
I don't think this is possible while doing an upgrade. However you can change the default directory if you are doing a new install for Cisco Works LMS.
