Upgrade IOS.
Answered Question
Jun 25th, 2007
I have below Switches and want to upgrade the software in all.
Device: WS-C2950SX-24
Software Version: 12.1(11)EA1-C2950-16Q4L2-M
Device: WS-2950G-48-EI
Software Version: 12.1(13)EA1-C2950-16Q4L2-M
Device: WS-2950T-24
Software Version: 12.0(5.3)WC(1)-C2950-C3H2S-M
I downloaded the below file
C2950 EI & SI IOS Image & Web Based Device Manager
c2950-i6q4l2-tar.121-22.EA10.tar
Can i use this image for upgrade in all the above mentioned switches ?
Please guide.
Correct Answer by mohammedmahmoud about 9 years 11 months ago
Totally agree with Narayan, and please note that, images that begin with c2950-i6q4l2 have both SI and EI feature sets integrated. The model of 2950 that you use determines the feature set that gets activated. When downloaded, the image recognizes the hardware and enables the appropriate set of features.
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_example09186a0080169627.shtml
HTH,
Mohammed Mahmoud.
Correct Answer by mrmozaffari about 9 years 11 months ago
yes ,but then you need to extract the ios because it is (tar).
Regards B.mozaffari
Please rate if helpful.
Overall Rating: 5 (4 ratings)
Correct Answer
mrmozaffari Mon, 06/25/2007 - 01:16
Regards B.mozaffari
royalblues Mon, 06/25/2007 - 01:18
  • Green, 3000 points or more
yes you can.
Make sure you have sufficient Flash and RAM memory available
Narayan
Correct Answer
mohammedmahmoud Mon, 06/25/2007 - 01:25
HTH,
Mohammed Mahmoud.
