Bandwidth Restriction on each port Layer 3750 Layer 3 Switch
Jun 25th, 2007
I have a Cisco 3750 layer 3 switch. I want to limit the bandwidth to 1 Mbps on each port of switch. Can i do that & if yes then How ?
Please let me know
royalblues Mon, 06/25/2007 - 01:45
Friend,
You can use policing to limit the bandwidth.
Switch(config)# access-list 1 permit any
Switch(config)# class-map ipclass1
Switch(config-cmap)# match access-group 1
Switch(config-cmap)# exit
Switch(config)# policy-map flow1t
Switch(config-pmap)# class ipclass1
Switch(config-pmap-c)# police 1000000 8000 exceed-action drop
Switch(config)# interface gigabitethernet2/0/1
Switch(config-if)# service-policy input flow1t
have a look at this link
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12225see/scg/swqos.htm#wp1044737
HTH, rate if it does
Narayan
sulekhnain Mon, 06/25/2007 - 20:47
Thanks a lot Sir,
I am able to control the input traffic on the port with about said configuration. But when I applly service-policy on output of port, it says that "Warning: Assigning a policy map to the output side of an interface not supported"
Please let me know how to apply service policy on output of port.
Sulekh Nain
Pavel Bykov Mon, 06/25/2007 - 02:48
Alternatively, you can do it over class-default, without using Access List.
eg:
policy-map LIMIT_1M
class class-default
interface range gigabit 1/0/1 - 24
service-policy input LIMIT_1M
sulekhnain Mon, 06/25/2007 - 20:48
Thanks a lot Sir,
I am able to control the input traffic on the port with about said configuration. But when I apply service-policy on output of port, it says that "Warning: Assigning a policy map to the output side of an interface not supported"
Sulekh Nain
