router 3825 performance
Jun 25th, 2007
Dear All
I took the following note from cisco site
Wire-speed performance on 3825 with services enabled at up to T3/E3 rates.
my quiestion is.
does this apply if i use Cisco Gigabit Ethernet Network Module to connect it to my service provider, in other words, can i get 1 GIGA throuput out of the router despite the upper statement using the GIG NM or using the SFP placed on the router.
Overall Rating: 4 (2 ratings)
royalblues Mon, 06/25/2007 - 01:52
The 3825 has a Switching capacity of 179 Mbps or 350,000 pps under ideal conditions.
I think you can safely load the router till the above value
Have a look at the attached document
HTH, rate if it does
Narayan
Richard Burts Mon, 06/25/2007 - 02:04
Emad
If it is rated for wire speed up to T3 (45 meg) then I would not count on getting wire speed using a Gig interface. The performance of the router is somewhat dependent on what you are asking it to do (how many services you enable on it) but I would not expect to get wire speed performance on the Gig interface.
Rick
OPS_account Mon, 06/25/2007 - 02:38
Thank you for the helpfull answer, is there document or link describing in more details these performance issues on routers and switches.
