Cisco ACS 4.1 - Not able to see Tacacs Admin info
Jun 25th, 2007
I have just upgraded to 4.1 and now I am unable to see Tacacs Admin info (When a command is typed it is no longer sent to the ACS server).
Here is my AAA config on the router:-
aaa new-model
aaa authentication login default group tacacs+ local
aaa authorization exec default group tacacs+ none
aaa authorization commands 15 default group tacacs+ none
aaa accounting commands 15 default start-stop group tacacs+
tacacs-server host 83.98.2.250
tacacs-server key *********
Does anyone have any ideas?
It says on ACS to put
aaa accounting commands start-stop tacacs+ which I have as you can see above but no joy.
Any help would be much appreciated.
Cheers
Steven
Richard Burts Mon, 06/25/2007 - 02:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Steven
We recently went through the same experience at a customer site. I was not directly involved so do not know the details. But there is a bug in 4.1 which produces this symptom (it is not a config issue on your devices) and Cisco has a patch for it. I am sure that if you contact TAC it would be easy to get the patch.
Rick
sadcock123 Mon, 06/25/2007 - 02:25
Cheers for the reply and info Rick.
Kind Regards
Steven
