linking two switches together.
Jun 25th, 2007
hi Guys ,
quick question in relation to joining two switches together,
can I link a 2950 switch with a 1000 BASE-SX with a 3560G with 4 SPF ports with fibre and what pitfalls should i look out for .
Thanks in advance
Kevin
Overall Rating: 3.5 (2 ratings)
royalblues Mon, 06/25/2007 - 03:06
  • Green, 3000 points or more
yes you can do that.
you would require 1000 BASE-SX module which requires SC connectors on the 2950.
While on the other hand the 3560G would require SFP i.e GLC-SX-MM= module and the LC connector
I do not see of any pitfalls in this scenario and we have used it successfully in our networks.
HTH, rate if it does
Narayan
kcornally Mon, 06/25/2007 - 03:09
when you say LC and SC what do you mean ,
I have the 1000 base-Sx in the 2950 , I ll check the 3560G.
farkascsgy Mon, 06/25/2007 - 03:12
  • Silver, 250 points or more
So you would like to connect GBIC to SFP, you need Multimode Duplex Fiber Optical cable with SC-LC connectors. If SFP to SFP you need the same cably type with LC-LC connectors.
http://www.cisco.com/en/US/products/hw/routers/ps341/prod_module_installation_guide09186a00801cc731.html
http://cisco.com/en/US/products/hw/modules/ps5455/products_data_sheet09186a008014cb5e.html
bye
FCS
Please rate me if I helped.
