DCA Server is Down in LMS 2.6
Jun 25th, 2007
Hi All,
this is the first time for me here and i have a technical problem that i can't solve.
I'm working on the LMS 2.6
and i have installed the:
Common Services 3.0.5
Resource Manager Essentials 4.0.5
Device Fault Manager 2.0.6
Campus Manager 4.0.6
Cisco View 6.1.5
but when i try to generate any report on the LMS there is a massage saying that the DCA Server is down i tried to enable it by all the means but i failed, i want to know is there a way to enable this server or i will have to install the LMS from the beginning again !!
jreekers Mon, 06/25/2007 - 07:14
  • Cisco Employee,
Hi.
Can you please verify all of your hostname entries as if you have recently changed the hostname on this server. You can check it against this page:
http://www.cisco.com/en/US/partner/products/sw/cscowork/ps3996/products_user_guide_chapter09186a008022f962.html#wp1078582
I think you may find that there is a hostname problem on this server. Did you by chance change the hostname after installing LMS 2.6?
HTH,
-Joe
m.samouka Mon, 06/25/2007 - 23:31
Thanks for your reply,
to shorten the distance... i have tried the 2 both solutions discussed in the below links and one of them was the case of changing the host name but niether of them is my issue here.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=Network%20Management&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1dddfd05
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=Network%20Management&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1dde708c/6
but in the above forum i don't understand what is ment by the SP2, does he mean SP2 of the Windows!! case i'm using windows server 2000 with SP4 installed.
