vkapoor5 Fri, 06/29/2007 - 06:15
  • Bronze, 100 points or more
Following is a summary of the steps you must perform to configure per-interface NetFlow and NDE on Cisco 7600 routers. Detailed procedures for each step are provided in the sections later in this chapter.
1. If you plan to export NetFlow statistics, globally enable NDE on the router by issuing the following commands:
configure terminal
ip flow-export destination
ip flow-export version
mls nde sender version
http://www.cisco.com/en/US/products/hw/routers/ps368/products_configuration_guide_chapter09186a0080699369.html#wp1160808
linker.team Fri, 06/29/2007 - 06:23
It is not a 7600. I have vrf interface on a router which push the traffic into an MPLS cloud. This interface has the IP address through which i can reach my LAN across the MPLS cloud. I wanna to use this interface as a source interface in the netflow data export.
linker.team Fri, 06/29/2007 - 06:48
Actually if I do ip flow-export source ?, it shows plenty of options. Even I am not able to find out thise options in Cisco docs. Also I dont know which is right one to specify the VRF interface.
linker.team Fri, 06/29/2007 - 06:57
In other words is it possible to specify an IP address instead of an interface?
