Question regarding structured cabling for VG224
Jun 25th, 2007
Hi all, hope someone can give some advice on this.
I have a VG224 located at the 5th storey of a building, in our server room. If I have fax devices located on every floor till 20th storey, what is the best way to connect them up?
I understand the connection has to go through the building riser. But what connection should I use? Copper wires? Category 3, 4 or 5 cables?
Is there any references that you could recommend?
Thanks so much!
Eugene
eug-c Mon, 06/25/2007 - 05:07
Think I may have answered my own question.
Looks like category 3 would be sufficient and would not be too costly.
This is a good website that explains on cabling.
Eugene
