VPN behind a proxy
Jun 25th, 2007
Hello I am at the customer site and whant to connect with my company via VPN Client Version But the customer is using a proxy with authentication by username and password. Do someone know a way how I can use my VPN client with this proxy? (I do have to put in the authentication to get internet access). Thank you fropm Germany, Ludwig
guibarati Mon, 06/25/2007 - 10:46
You most likely will not be able to access it through the proxy, you will need to be connected directly to the internet, or at least with an NAT from inside network to outside network. The proxy as the name says just proxys http, https and sometimes ftp connections. (assuming it's a web proxy)
