WLC 4404 Security
Jun 25th, 2007
Dear All,
i need to implement the wlc into one of my customer.
The security issue as below has to be solved.
How can we stop the APs to send the discovery request to the wlc.We need few APs to be associated with it.If any one insert the APs to send the recovery and join the wlc THATthreat to be identified and blocked.
This is the major security issue needs to be solved.
What featre in the wlc that can be used to solve the problem.
swami
mchin345 Fri, 06/29/2007 - 10:01
You configure WLC to make APs configure against the Radius Server. On the WLC Web GUI:Security>RADIUS authentication>New> , Add ACS server IP, ASCII Shared secret, port number and check the boxes for
network user, management, IPSEC if used for AAA authentication , On the ACS server: Network Configuration>Add entry>
Add WLC hostname, IP address and matching shared key, for authenticate , using select RADIUS Cisco Aironet or Cisco Airespace if using ACS 4.0 , To configure the WLC so AP's authenticate against ACS: On the WLC: Security>AP Policies>Select the checkbox for Authorize APs against AAA, On the ACS server:, Add a user account for the MAC address of the AP with no dots or dashes, the password will also be the MAC address of the AP with no dots or dashes.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
