Restoring a Cisco ACS Windows 3.3 to a applicance acs 3,3 problem
Answered Question
Jun 25th, 2007
I have currently built an ACS appliance and am trying to restore the current config and database on the windows box. When i start the restore on the ACS appliance it says it is restoring but it is still doing this an hour later. Then when i reboot the box i get a invalid admin connection message and have to reset it using the cd.
Has anyone come across this?
How did you resolve it?
Cheers
Kev
Correct Answer by Jagdeep Gambhir about 9 years 11 months ago
Kevin,
Was there any security set on windows backup ie "Allow all IP addresses" to connect for Admin user ?
If you try from another computer do you get same message ?
~JG
Overall Rating: 5 (1 ratings)
rochopra Mon, 06/25/2007 - 07:49
  • Cisco Employee,
Make sure you are running similar version of ACS on windows and appliance
run following command on windows box
csutil -q -d -n -l
then take backup and
then restore backup on ACS appliance
Correct Answer
Jagdeep Gambhir Mon, 06/25/2007 - 07:50
  • Red, 2250 points or more
Kevin,
~JG
kevinhobson2000 Tue, 06/26/2007 - 00:37
It would appear that the access-policy was blocking the restore.
Thanks for the help.
Kev
