Connection design for (1) 4510 and (5) 3750's
Jun 25th, 2007
We have one Cisco 4510 and 5 3750's and we want to connect the 3750's to the 4510 and I'm trying to determing the optimize solution. Should I stack the 3750's and then connect to the 4510? Should I connect each switch individually (use trunking?). Should the 3750's be all one VLAN (voice and data required).
o_albegov Mon, 06/25/2007 - 08:25
It depends on what supervisor is installed in 4510. Which line cards do you have in 4510? What configuration of 3750 you have? Do they have a 10G ethernet port?
