Cat 6009 : System drawing more power than the power supply rating
hardik_tankaria
Hi Folks,
I have Cat 6009 with 6.4 sw version.
firstly, one of my power supply not being recongnized and though redundant power supply is being noticed by the system but continuously giving below messege.
2007 Jun 25 18:51:26 %SYS-5-PS_REMOVE:Power supply 2 has been removed
2007 Jun 25 18:51:28 %SYS-5-PS_INSERT:Power supply 2 has been inserted
2007 Jun 25 18:51:28 %SYS-2-PS_OK:Power supply 2 okay
2007 Jun 25 18:51:28 %SYS-1-SYS_ENABLEPS: Power supply 2 enabled
2007 Jun 25 18:51:55 %SYS-2-PS_FAIL:Power supply 2 failed
main cause is below error:
2007 Jun 25 14:40:33 %SYS-1-SYS_OVERPWRRTNG:System drawing more power than the power supply rating
While searching on Cisco found to be problem related to hw and sw compitiblity but same configuration of hw and sw is working fine with other setup.
Sup : WS-X6K-SUP1A-2GE
Sw : cat6000-sup.6-4-6.bin
PS : WS-CAC-4000W-INT
Kindly provide a solution.
Hardik..
paolo bevilacqua
Suggest you contact the TAC for this issue because seeing the PS "flapping" is not normal.
Try reseating both power supplies and see if that helps.
Sundar
