Loading MOH to a router?
Jun 25th, 2007
Looking for how to load MOH for an SRST site. I have a 2851 and wav file for the MOH. Once it is loaded, I should be able to configure the source in CCM correct?
Sorry, new to flash IOS MOH load. Im used to doing it through Windows.
Thanks!
Overall Rating: 5 (1 ratings)
Tommer Catlin Mon, 06/25/2007 - 10:54
Do you know if you have configure the router first before you can tftp the wav file to flash?
I have:
copy tftp flash
ip tftp server
file name onhold.wav
and it errors out.
mchandak Mon, 06/25/2007 - 10:57
No, you dont have to configure the router before you copy the file from tftp to flash. What is the error msg you get when try to copy the file ?
Tommer Catlin Mon, 06/25/2007 - 11:01
no worries, it was TFTP server.. Duh..... not in the root for copying.
thanks!
