mac address filtering
Jun 25th, 2007
I am trying to setup a mac address filter to prevent specific machines from accessing an ssid that I have setup for guest access. The config basics on my switch-
mac access-list extended LocalDevices
permit host xxxx.xxxx.xxxx any
permit host yyyy.yyyy.yyyy any
vlan access-map NoAccess 10
action drop
match mac address LocalDevices
vlan access-map NoAccess 20
action forward
vlan filter NoAccess vlan-list 305
If I then connect the network with a machine that is included in that list (xxxx.xxxx.xxxx for example), I should not be able to pass traffic through that vlan correct? Maybe I am mis-interpreting what this rule is supposed to do, or I didn't set it up correctly.
Dave
criss_noh Tue, 06/26/2007 - 22:51
It looks missconfiguration opposited to.
I would configure as following.
action forward
applied vlan will be under vlan305 and only get permittion for xxxx.xxxx.xxxx, yyyy.yyyy.yyyy. as for any mac apperently will be dropped.
is it clear ?
dsturgeon Wed, 06/27/2007 - 03:28
The goal is to drop all traffic from the addresses in the 'LocalDevices' acl, then allow everyone else. Is this not possible?
Dave
criss_noh Wed, 06/27/2007 - 17:11
If your goal is that, your configuration is correct 100% sure.
MAC xxxx.xxxx.xxxx ,of course, can not pass through by your configuration.
source xxxx.xxxx.xxxx : deny
source yyyy.yyyy.yyyy : deny
any MAC : permit
For my config
source xxxx.xxxx.xxxx : permit
source yyyy.yyyy.yyyy : permit
any MAC : deny
dsturgeon Thu, 06/28/2007 - 02:02
Ok, that is what I thought that it should work and those included addresses should not be allowed to pass. So....then why are they not dropped?
I have tested this with a couple different mac addresses that are included in the list, and on the specified vlan they are allowed to pass traffic. Hmmm.....
