Jon Marshall Mon, 06/25/2007 - 12:34
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
As Edison has said the Supervisor 720 supports a 720Gbps switch fabric ie each slot aupports 2 x 20Gbps connectors to the switch fabric. So for example on a 6509 switch
2 x 20Gbps = 40Gbps x 9 = 360.
Cisco then multiple this figure by 2 for full duplex transmission to get 720Gbps.
So AFAIK with a 6504-E chassis you would get
2 x 20Gbps = 40Gbps * 4 = 160 Gbps x 2
= 320Gbps capacity.
Jon
