ASA 5510 failover question
Jun 25th, 2007
Hi.I have 2 ASAs in failover and the provider that is providing the internet link and the link to our main office has done the following.
Over the same optical cable I have 3 IP ranges coming.First is a point-to-point range for connecting our devices,second one is a directed IP route range with 4 usable addresses and the third over which comes the range for connection to the main office with plenty of usable addresses.
How would I make a failover configuration for this kind of link?I suppose I can make different subifs and VLANs for each range but as I understand it I need 2 addresses to make failover viable.
Can a failover be done at all as I have only 2 addresses available in the point-to-point range between our devices or is there some way around this?
Thanks in advance for any help.
potenitally depending on what version of software you are running, you could perhaps be able to configure failover, simply excluding the outside interface.
I've never been required to configure it this way, when failover is configured you may simply be able to not configured the failover address for the outside interface.
There is a command "monitor interface" so a "no monitor interface outside" may help.
I would be interested to know if this would work.
Tim
