using the BGP community string
I am trying to determine what I am doing wrong when trying to set a community for BGP routes originating from my head router.
Here is the config info
network 192.168.252.0 route-map SetCommunity
route-map SetCommunity permit 10
match ip address prefix-list Filter_Remote
route-map SetCommunity permit 20
set community 0:19 65002:19
route-map SetCommunity permit 30
ip prefix-list Filter_Remote seq 10 deny 172.29.10.0/24
ip prefix-list Filter_Remote seq 20 permit 0.0.0.0/0 le 32
When I do a sh ip bgp 192.168.252.0 on a remote router I don't see the community tag.
sho ip bgp 192.168.252.0
BGP routing table entry for 192.168.252.0/24, version 103
Paths: (1 available, best #1, table Default-IP-Routing-Table)
Not advertised to any peer
13979 65002
172.26.185.1 from 172.26.185.1 (12.123.67.17)
Origin IGP, localpref 100, valid, external, best
Any ideas?
Overall Rating: 5 (1 ratings)
Edison Ortiz Mon, 06/25/2007 - 12:37
  • Hall of Fame,
    Founding Member
You need the
neighbor [neighbor ip] send-community
command under the BGP process.
I believe you want your set community statement under the route-map SetCommunity permit 10 entry (since right now line 10 isn't setting anything and line 20 isn't matching anything).
mohammedmahmoud Mon, 06/25/2007 - 12:43
  • Green, 3000 points or more
Communities are not sent by default, you'll need
"neighbor send-community".
[edit] and i also agree with Jonathan on his suggestion.
HTH,
Mohammed Mahmoud.
