Static across an IOS to IOS VPN
Answered Question
I have a situation where I own both sides of a VPN tunnel between IOS boxes with no NAT at all. However, I have 2 servers that I now have to static NAT to two brand new IP addresses to meet network requirements on the "far" end. Unfortunately I never NAT on an IOS device--always a PIX/ASA or VPN-3000 box, and just haven't gotten the hang of it from the configuration examples.
A basic example of how to do this (without NATing any of the other traffic) would be greatly appreciated.
Correct Answer by sundar.palaniappan about 9 years 9 months ago
Just configure static NAT for both servers. Here's a sample config.
int e0
description 'LAN'
ip address 172.16.1.1 255.255.255.0
ip nat inside
int e1
description 'Internet'
ip address 192.168.1.1 255.255.255.248
ip nat outside
ip nat inside source static 172.16.1.254 10.1.1.254
172.16.1.254 --> Real Address of the Server.
10.1.1.254 --> Global address of the Server to which the far end user sends traffic to.
Sundar
Overall Rating: 5 (1 ratings)
Correct Answer
sundar.palaniappan Mon, 06/25/2007 - 15:18
  • Green, 3000 points or more
int e0
description 'LAN'
ip nat inside
int e1
ip nat outside
Sundar
Sundar,
Thank you. Please verify for me that this will not cause any negative impact on the other traffic on the network, for instance requiring me to write NAT rules for anything else? I just want to be certain before I proceed as it is a production system and I don't have the luxury of a test-system right now.
sundar.palaniappan Tue, 06/26/2007 - 15:50
There's no need for explicit NAT rules for other traffic and they would continue to pass un-natted. The one thing you would have to do is, if you aren't doing GRE tunneling with IPSEC, your crypto access list should permit traffic to the NAT (global) address of the Server to be encrypted. The other side should mirror this access list.
Sundar
