Searching network drives via VPN
Hi Jim
Are you able to get the users to enable NetBIOS over TCP/IP on the adapter that you use to connect to the domain, this is done by:
Go to the Properties of the Ethernet Adapter.
Select TCP/IP and click Properties.
Click Advanced.
Click the WINS tab.
Check the Enable NetBIOS over TCP/IP option
Then log on.
Regards MJ
