how to disable napster on 1841
Jun 25th, 2007
When i run the following command ion the 1841 router
sh ip nbar protocol-discovery top-n 20
I see napster along with unknown traffic.
The question is how can I disable outgoing napster traffic and how to determent unknown protocols being used from inside out.
Thank you for any help
mohammedmahmoud Mon, 06/25/2007 - 13:01
Here you are a method to block napster:
class-map match-any napster
match protocol napster
policy-map mark-napster
class napster
set dscp 1
interface FastEthernet0/0
service-policy input mark-napster
interface Serial1/0.1 point-to-point
ip access-group 103 out
access-list 103 deny ip any any dscp 1
access-list 103 permit ip any any
Mohammed Mahmoud.
visteknetworking Mon, 06/25/2007 - 13:17
Hi ,
assuming that my LAN interface is fastethernet 0/0 and the 0/1 goes to the WAN.
I guess that in your case serial is the WAN.
all the rest should be as you have typed, correct?
royalblues Mon, 06/25/2007 - 18:34
Yes, in your case the WAN link would be fa 0/1 where you will apply your policy-map.
The configuration suggested by mohammed does does marking at the input and uses an access-list at the output
If you want to drop the traffic, you can also police the napster traffic to the minimum value and drop it when this exceeds
policy-map mapster
class napster
police 8000 exceed-action-drop
HTH, rate if it does
mohammedmahmoud Mon, 06/25/2007 - 23:02
Yes as Narayan has told you, your f0/1 would be the WAN link (instead of the serial in my case), and there are multiple ways to do it, and Narayan's example is another valid example.
Mohammed Mahmoud.
