JORGE RODRIGUEZ Mon, 06/25/2007 - 13:58
  • Green, 3000 points or more
show mac-address-table dynamic .. that is if this is a layer 2 switch, this command will only show layer 2 MAC addresses, is this switch is connected to a router you need to go into a router and reference the mac adddress in question retreaved from the switch to aquire the layer 3 address.
on the router then you can issue:
show ip arp 0099.3334.3334 this is the 48Bit hardware address retreaved from the switch.
Jorge
mark.j.hodge Mon, 06/25/2007 - 14:01
  • Bronze, 100 points or more
Not directly, you can find the MAC address of connected devices, and then look those addresses up in the ARP table. It can be a tedius operation, but there are tools out there that will automate the process.
