Translation Rule
Jun 25th, 2007
Hi, is there any possibility that you can manipulate the ANI and translate it to DNIS. For example when your ANI is 12345 and your called number is 67890 on the translation rule when the ANI is matched it will translate it to DNIS (67890). Is this possible on cisco? any suggestions? My objectives is i want to translate the ANI into DNIS. Thanks in advance
Paolo Bevilacqua Mon, 06/25/2007 - 14:01
You cannot translate the ANI into DNIS, but you can influence the call routing based on the ANI, matching "answer-address" in dial-peer.
If you can make an example of what you are trying to do, and the complete call-flow, I could be more specific.
