Warning message
vlan trunk across isp network
Jun 25th, 2007
I'm trying to create a trunk across a link that my isp has given to me. I have a 3550 at both ends and I need to move across a couple of vlans.
I have tried this config and the trunk comes up, but I cannot transfer any ip information across it.
This is configured on both ends:
interface FastEthernet0/1
switchport access vlan 509
switchport trunk native vlan 509
switchport trunk allowed vlan 509
switchport mode trunk
end
Do I need to create a tunnel or something first?
Dan.
Edison Ortiz Mon, 06/25/2007 - 18:26
  • Hall of Fame,
    Founding Member
Do you have a SVI for VLAN 509 at each switch ?
If so, let's see the show ip int brief from each switch as well as show vlan and show trunk
danletkeman Mon, 06/25/2007 - 20:07
switch1#sh ip interface brief
Interface IP-Address OK? Method Status Prot
Vlan509 10.50.9.24 YES manual up up
FastEthernet0/8 unassigned YES unset up up
switch2#sh ip interface brief
Vlan509 10.50.9.3 YES manual up up
FastEthernet0/2 unassigned YES unset up up
switch1#sh interfaces trunk
Port Mode Encapsulation Status Native vlan
Fa0/8 on 802.1q trunking 509
Port Vlans allowed on trunk
Fa0/8 509
Port Vlans allowed and active in management domain
Fa0/8 509
Port Vlans in spanning tree forwarding state and not pruned
Fa0/8 509
switch2#sh interfaces trunk
Fa0/2 on 802.1q trunking 509
Fa0/2 509
Fa0/2 509
Fa0/2 509
The vlan exists on both switches when i type sh vlan
I have other trunk's setup on these switches to other locations on my own network. The only one that cannot transfer any traffic is the one over the isp link.
Edison Ortiz Tue, 06/26/2007 - 07:41
  • Hall of Fame,
    Founding Member
I'm assuming you are unable to ping from site A to site B ?
Edison Ortiz Tue, 06/26/2007 - 10:56
  • Hall of Fame,
    Founding Member
Did you verify with the ISP that 509 is the transit VLAN ?
Did you try creating an additional VLAN (say, 510) and make that the L3 VLAN (of course, you will have to allow that VLAN in the trunk as well).
danletkeman Wed, 06/27/2007 - 05:56
Unfortunately I cannot rely on the isp in this situation. Is there a way I can create a tunnel or something of that sort?
Edison Ortiz Wed, 06/27/2007 - 07:34
  • Hall of Fame,
    Founding Member
The ISP supplies the end-to-end connectivity here. If their L2 configuration is not done correctly, you won't be able to establish a L2 or L3 connection between these locations.
