Verizon IP Trunk and CME/CUE, call transfers failing
Jun 25th, 2007
Anyone experiencing the issue using a SIP trunk and CM cannot transfer calls when initiated on the trunk. There is no issue when the call is initated on a analog line connected to an FXO port.
paolo bevilacqua Tue, 06/26/2007 - 00:39
  • Hall of Fame,
    Founding Member
CM or CME? If the latter which version?
If recent enough, you need to cofigure
voice service voip
no supplementary-service sip moved-temporarily
And CME will stop trying to do SIP-based transfers.
paolo bevilacqua Fri, 10/19/2007 - 14:21
  • Hall of Fame,
    Founding Member
For CME, the commands I've mentioned above.
